1.3.1 - draw - incorrect watermark positioning when win scale <>100%
XnView: MP 1.3.1 64bits
OS: Windows 64bit (21H1), display resolution 3840x2160, win scaling 150%
Draw tool - incorrect watermark positioning
My test image is 1000x1000px, watermark places somewhere at 1500px in some cases.
2. open image
3. open Draw tool (Shift+D)
4. insert watermark
5. try to position it anywehere, except top-left corver
Actual behaviour:
Only Top-Left corner option position Watermark correctly, all other options do not.
It looks like image size determines incorrectly (e.g. original +50%)
Expected behaviour:
Watermark shall position correctly within image size.
Suggestion (default position):
Current default position of inserted watermark is something like "center-top -10%".
Guess it shall be something from the existing list (e.g. Top-Left corner).
Re: 1.3.1 - BUG - draw - incorrect watermark positioning
i can't reproduce, could you send me files used?
xnview wrote: Sun Oct 23, 2022 1:12 pm i can't reproduce, could you send me files used?
It works with any image.
I have located the issue - it caused by win scale, 150% in my case.
There is no issue in the following cases:
- when I change win scale to 100% OR
- when I run program with -noDpiScaling param
Re: 1.3.1 - draw - incorrect watermark positioning when win scale <>100%
fixed in 1.4.0b1
