1.3.1 - catalog - 'Relocate folder' has no path validation
XnView: MP 1.3.1 64bits
OS: Windows 64bit (22H2), display resolution 3840x2160, win scaling 150%
Settings → Catalog → Catalog tab
'Relocate folder' functionality has no path validation.
2. open Settings (F12)
3. goto Catalog → Catalog tab
4. press 'Relocate...' button and select root directory, e.g. c:\
Actual behaviour:
User can type anything in 'New path:' field
Expected behaviour:
Guess there shall be standard folder selection dialog
Re: 1.3.1 - catalog - 'Relocate folder' has no path validation
xnview wrote: Wed Oct 26, 2022 12:51 pm :bugconfirmed: Thanks to your detailed description I can reproduce the problem.
partially fixed in 1.4.0b1:
- OK - it does not allow to replace root path (e.g. E:\) with not_valid_path
- BUG - it still allows to replace long path (e.g. E:\test\) with not_valid_path
This problem is supposed to be fixed in XnView MP 1.4.0. Please check and confirm the bug fix here.
xnview wrote: Tue Dec 13, 2022 7:36 am This problem is supposed to be fixed in XnView MP 1.4.0. Please check and confirm the bug fix here.
1.4.5
issues still remain - it still allows to replace long_path (e.g. "e:\test\") with not_valid_path (e.g. "qqq")
as described in my message above
