1.3.1 - white balance - incorrect colors
XnView: MP 1.3.1
OS: Windows 64bit (22H2), display resolution 3840x2160, win scaling 150%
Image menu → Map → White Balance...
'White Balance' does not work as expected, even with with default settings.
2. navigate to test image and open it in Viewer mode
_test_image.zip
(68.46 KiB) Downloaded 53 times
3. goto Image menu → Map → White Balance...
4. tick 'Apply to image' checkbox
image turns green
Re: 1.3.1 - white balance - incorrect colors
i can't reproduce, it works correctly
xnview wrote: Thu Oct 27, 2022 1:51 pm i can't reproduce, it works correctly
I have updated initial post with steps and test file. Hope it helps.
Please also check related issue (I doubt this is desired behaviour):
Image turns black when intencity reach some point (depends on the image).
On this test image it is 71, but it can be less on another image.
fixed in 1.4.0b1
