XnView: MP 1.3.1 - 64-bit
OS: Windows 10 - 64-bit
Archive browsing does not support Unicode filename. If image or folder inside the Archive has Unicode filename, XnView can't show images correctly.
1, there are a 4 images without Unicode filename. Make a Archivewith them. browse it by xnview MP.
everything is fine.
and here is the Archive.
2, Now rename the images to Unicode filename.
You can notice that xnview MP can not work with it.
Archive browsing does not support Unicode filenames
Re: Archive browsing does not support Unicode filenames
This problem is supposed to be fixed in XnView MP 1.4.0. Please check and confirm the bug fix here.
