1.3.1 - settings - thumbnail label color
XnView: MP 1.3.1 64bits
OS: Windows 64bit (22H2), display resolution 3840x2160, win scaling 150%
Settings
Incorrect thumbnail's label color in settings.
2. open Settings (F12)
3. goto Thumbnail → Labels
4. select any item in 2nd list (e.g. Filename)
issue A
5. text and background colors shown as black, but in Browser mode they are black/gray
issue B
5. press 'Reset color' button
background color will change to white, but it will not affect labels in Browser mode
Expected behaviour:
guess colors shall be the same as in XnView Classic
Suggestion:
reposition 'Text color' above 'Background color'
Re: 1.3.1 - settings - thumbnail label color
not easy, black is used to represent 'default color'. And 'default color' depends on 'Settings>File list>Format colors'
Perhaps better to show that color is not used:
xnview wrote: Thu Nov 17, 2022 10:43 am Perhaps better to show that color is not used: Clipboard-1.jpg
+1, looks good
also Reset button shall set color's UI to the same 'crossed' state.
This problem is supposed to be fixed in XnView MP 1.4.0. Please check and confirm the bug fix here.
fixed in 1.4.0
