1.3.1 - settings - icc - CMYK profile Other option does not enable file selector
XnView: MP 1.3.1 64bits
OS: Windows 64bit (22H2), display resolution 3840x2160, win scaling 150%
Settings
CMYK Profile Other option does not enable file selector until RGB Profile Other selected.
2. open Settings (F12)
3. goto General → ICC tab
4. tick 'Use ICC profile..' checkbox
5. select Other in CMYK group
file selector remains disabled
6. select Other in RGB group
only now it is possible to set CMYK Other
Re: 1.3.1 - settings - icc - CMYK profile Other option does not enable file selector
xnview wrote: Tue Nov 22, 2022 1:59 pm :bugconfirmed: Thanks to your detailed description I can reproduce the problem.
still experience this issue in 1.4.0 beta 1
right, will be fixed in beta 2
fixed in 1.4.0b2
