One tab per image when double-clicking
Post by Guest »
hi, ok. for every suggestion one thread?!...
1. I tried for like half an hour to find an option to turn on the multiple tab loading. now it seems, that you can only open multiple pictures in multiple tabs by first choosing the thumbnails -> RMB -> open all selected. as an tabbed-browser-user this is a wicked behavior. would like to have for each doubleclicked picture a separate tab, and not using only one tab by doublecklicking a thumb and closing all other tabs?!
Clo wrote::) Hi !
1. This is not true; you can always get one tab per file, as well from a thumbnail as from any pic file open from the "File" menu (or the similar button)
how? every time a doubleclick a thumb in the browser it opens the same tab! :think:
Re: tab behavior
Anonymous wrote:hi, ok. for every suggestion one thread?!...
Clo wrote::) Hi !
In browser, you have "open all"
Re: tab behavior
Post by Guest »
xnview wrote:
Anonymous wrote:
Clo wrote::) Hi !
? thats what i wrote..
most of the people have tabbed browsers.
why don´t adapt this behavior? double click on thumb -> open a NEW tab. simple as this.
Re: tab behavior
Anonymous wrote:
xnview wrote:
Anonymous wrote: how? every time a doubleclick a thumb in the browser it opens the same tab! :think:
I don't understand, when you click on a thumb you have a new tab
Re: One tab per image when double-clicking
Anonymous wrote:... how? every time a doubleclick a thumb in the browser it opens the same tab! :think:
Could you please verify whether checkbox "Only one view opened" in "Tools > Options > View" is unchecked. If it is checked, there will be only one tab, always.
Post by Guest »
ah, thanks, that did the thing, helmut :).
missed that one!
finally..
