b2: Make so-called fullscreen lite disappear!
Xyzzy
Post by Xyzzy »
Hello!
Please make full-screen lite disappear, so that when image is displayed in fullscreen, it behaves always the same way, has the same avaliable options and there are no Options that refer only to one of the fullscreen "modes".
X.
XnView 1.82 <x>
Re: REQ: Make so-called fullscreen lite disappear!
Xyzzy wrote:Hello!
X.
I strongly support this: Fullscreens must be 100% identical. See also discussion and comments in topic "1.80: Two Fullscreen modes?".
Xyzzy wrote:Hello!
Sorry but i can't, fullscreen from view mode have some editing capabilities, fullscreen from browser has not.
Post by Guest »
I assume that they cannot be added to 'fullscreen from Browser' for some reason?
If so, frankly I'd like 'editing' removed from fullscreen from View.
X.
Olivier_G
Post by Olivier_G »
I support (my opinion is here).
Olivier
Support++
:) Hi !
- I support too ! This is too confusing.
:mrgreen: Kind regards,
ckit
Post by ckit »
So, you want Pierre to remove "View in Fullscreen - F11" from the Browser menu's and Browser?
That is what Fullscreen Lite means by the way.
This is stupid and will not happen as long as I'm around!
Olivier_G
Post by Olivier_G »
ckit wrote:So, you want Pierre to remove "View in Fullscreen - F11" from the Browser menu's and Browser?
That's not what we want. We just want a single kind of Fullscreen, wether you start it from Viewer or Browser... instead of having different behaviours/menus for each of them (cf: Fullscreen 'normal' and Fullscreen 'abnormal/light')
Moreover, having to maintain 2 different solutions to do the same thing seems counterproductive to me.
ckit wrote:This is stupid and will not happen as long as I'm around!
No trouble. You can still stay around, as you can see... :D
Olivier
PS: I don't request it for 1.82, because Pierre explained that there are issues in both normal fullscreen (cf: MDI+jumping) and in lite fullscreen (cf: editing): it would mean heavy changes to solve either one.
Olivier
I can't change that for 1.82, but in next version i'll make fullscreen from browser the only fullscreen mode...
xnview wrote:... I can't change that for 1.82, but in next version i'll make fullscreen from browser the only fullscreen mode...
Just to make sure and be clear: I do want fullscreens available from both browser and image view. But I do not want fullscreens that behave differently.
Yes :-) Current fullscreen from browser has more features than old one, fullscreen can be for example on a second monitor.
That'll be good. When will 1.83 release? ;-)
Olivier_G
Post by Olivier_G »
xnview wrote:I can't change that for 1.82, but in next version i'll make fullscreen from browser the only fullscreen mode...
Thank you, Pierre. It sounds interesting... :D
Xyzzy
Post by Xyzzy »
So Postponed.
X.
Danny
Post by Danny »
I don't mind if it won't make displaying any slower.
