B3: Still missing sort by options
ckv
Post by ckv »
I think the "Create Web page" and the "Batch Rename" should at least have 'Name (Numeric)', 'EXIF Date' and 'Image size' sort by options.
XnView 1.82 <x>
Re: B3: Still missing sort by options
ckv wrote:I think the "Create Web page" and the "Batch Rename" should at least have 'Name (Numeric)', 'EXIF Date' and 'Image size' sort by options.
In Batch rename sort by name is sort by name numeric :-)
Image size is needed for rename??
ckv
Post by ckv »
xnview wrote:In Batch rename sort by name is sort by name numeric :-)
Oh yeah I didn't notice that.
xnview wrote:Image size is needed for rename??
Well it's quite trivial, but I think sooner or later someone want's to rename images sorted by the image size.
Xyzzy
Post by Xyzzy »
EXIF date present in rc1.
As for Image size Postponed because GUI freeze in rc1.
X.
darkfader
Post by darkfader »
What about sorting by:
  • image/resolution width
    image/resolution height
    number of pixels (width * height)
    aspect ratio (width / height)
    compression ratio (number of pixels / filesize)
Should be fairly easy to implement all these in one go.
Beware of division by zero.
darkfader
Post by darkfader »
Another idea is to sort on graphic content. I googled a bit and saw that ThumbsPlus has it.
It stores three fields for Image Similarity Metric in its thumbnail ODBC database.
Some paper about it: http://citeseer.ist.psu.edu/frese97methodology.html
brahman_pl
Post by brahman_pl »
I'd love to have sorting by aspect ratio.
I am a photographer and I need to resample images that are not standard format to be printed. That means I need to separate square images (1:1) and panoramas (2:1) from standard (3:2). Other sorting options are not very useful since I often crop my images.
