Possible handle leak
ckv
Post by ckv »
While browsing with XnView the handles increase constantly. This isn't normal rigth? This occurs with all XnView versions what I have currently.
To reproduce, just browse with XnView or if you want to increase handles fast, just hold F9 down in folder what haves a lot of files and monitor handles and memory usage with Process Explorer or windows task manager.
Heres a picture from Process Explorer while holding F9 button down in browser.
Handle increase in XnView
Re: Possible handle leak
ckv wrote:While browsing with XnView the handles increase constantly. This isn't normal rigth? This occurs with all XnView versions what I have currently.
Do you have the problem with RC1?
ckv
Post by ckv »
Yes. That Process Explorer picture is from RC1.
ckv wrote:Yes. That Process Explorer picture is from RC1.
I have a little leak on windows 2K, but not on WinXp
ckv
Post by ckv »
OK. I use win2K, but I will test this also in XP whan I get a chance.
Edit: and maybe also in windows 98 :)
ckv
Post by ckv »
I tested this in XP and have a small leak also in XP. I made more testing and it seems that the View as list mode don't have the leak in both win2k and XP.
The only noticeable difference between view as list and the other view as modes is the file name backround color for the different file types. Could the leak be there? Anaway disabling that color don't stop the leak.
