slideshow should scroll panorama pictures
Dirk
Post by Dirk »
my idea/wish is that the slideshow should have an option for scrolling a panaroma.
Re: slideshow should scroll panorama pictures
Dirk wrote:my idea/wish is that the slideshow should have an option for scrolling a panaroma.
So for example, set 'fit to window height', and scroll the picture?
Dirk
Post by Dirk »
yes pierre, :)
maybe some people always prefer to fit a picture in the window.
but if you have a big panorama picture you will see only a small "line".
therefore the slideshow should have an option "automatic scrolling of panorama pictures". if this is enabled, then use picture/windows heigth and scroll the picture from rigth to left.
second step/ nice-to-have-features:
- speed of scrolling
- automatic scrolling than ratio of height and weigth is bigger than 1:XXX
lalaka
Post by lalaka »
just want to note that Dirk is not alone here with that wish - this would be a *very* nice feature! :)
Some way of automatically determining what pictures should be considered panoramic is essential, but IMHO not too hard: just add an option for an aspect ratio limit, e.g. anything wider than 3:2 will be considered a panorama.
It would also be nice if that worked for vertical panoramas (scrolling vertically) as well as for "normal" horizontal panoramas.
Cheers, Lars.
P.S.: Combined with the suggestion posted here, this would make XnView a perfect slideshow presenter for large screens (beamer/projector):
http://newsgroup.xnview.com/viewtopic.php?f=34&t=9892
romuloff
Post by romuloff »
Was this feature implemented ?
I'm looking for a image viewer that has slideshow feature and can 100% pan in when the image is a panorama ( scrolling in it )
I tested XnView because of this topic but haden't found the feature.
