Rc1: Cleaned jpg increased file size.
Taboc
Post by Taboc »
Some jpg increase file size when Clean:Optimize huffman table is unchecked.
http://img64.imageshack.us/img64/3416/13kz1.jpg
http://img64.imageshack.us/img64/7514/22ju1.jpg
XnView 1.82 -
Xyzzy
Post by Xyzzy »
Yes, there is something wrong about Clean.
Files with no EXIF/IPTC data grow after they are cleaned with EXIF/IPTC related options checked.
X.
Re: Rc1: Cleaned jpg increased file size.
Taboc wrote:Some jpg increase file size when Clean:Optimize huffman table is unchecked.
Seems to be correct :-) All other software with a clean feature have this behaviour...
Dreamer
Post by Dreamer »
So close?
Not always…
:) Hello !
Seems to be correct All other softwares with a clean feature have this behaviour…
… that doesn't mean it's normal and logical…
- I tested with the image below, and got a small gain at size, ~4KB less…
—————Image
- Please, could you check whether you get the same ?
{ BTW : the caption on the pic tells «I've also MY anti-virus ;) }
:mrgreen: Kind regards,
Claude'
FlorianH
Re: Not always…
Post by FlorianH »
Clo wrote:- Please, could you check whether you get the same ?
I can confirm:
a) original file 58.191 bytes
b) original file cleaned with all options except optimize -> 58.191 bytes (same size)
c) original file cleaned with all options (incl. optimize) -> 54.259 bytes
d) file c) cleaned with all options except optimize -> 58.191 bytes strange!
I think from the technical point of view (pierre's view?), behaviour b) is ok. But behaviour d) is not realy easy to explain...
Dreamer
Post by Dreamer »
Moved back to New/Open, since it's still not clear if current behavior is standard or not.
Dreamer wrote:Moved back to New/Open, since it's still not clear if current behavior is standard or not.
There is no bug here :-)
Olivier_G
Post by Olivier_G »
Seems strange that removing data actually increase filesize... :(
-> can't you actually remove the corresponding metadata space completely ?
Olivier_G wrote:Seems strange that removing data actually increase filesize... :(
Metadata is removed, but i think that huffmann code is rearranged.
Xyzzy
Post by Xyzzy »
OK, I think this solves the puzzle. But is there any need to NOT optimize Huffman tree?
X.
Olivier_G
Post by Olivier_G »
More tests:
I converted a TIFF to JPEG (no Huff Optimization) -> image without metadata: 323644 B
I added several IPTC&Comments -> 323977 B
I cleaned those metadata (no Huff Optimize) -> 323644 B
=> back to original size without metadata (optimize Huff gives 320305 B).
It looks fine to me regarding the way metadata are handled.
(and also regarding Huffman table optimization)
Olivier
Xyzzy
Post by Xyzzy »
Xyzzy wrote: OK, I think this solves the puzzle. But is there any need to NOT optimize Huffman tree?
Self-reply :)
Yes, when there is image with already optimized coding (fe. by some specialized packer)- applying Huffman could grow it. Looking at Olivier_G test it can be Closed, right?
X.
