High Quality in fullscreen lite is set with... Preview???
Olivier_G
Post by Olivier_G »
I just realized by visual and timing comparisons that:
- Options>View>'High Zoom Quality' are for View (windowed/fullscreen) only ...ie: not Fullscreen lite
- Browser>Preview>Use High Quality and View>Fullscreen>Use delayed HQ... are for Preview AND Fullscreen lite.
Tricky... :mrgreen:
Should it be solved for 1.82?
...or only once that Normal/Abnormal fullscreen schizophrenia is cured?
Olivier
XnView 1.82 <x>
marsh
Post by marsh »
But, current options would behave logically when that technical wizardry is done. Yes?
Olivier_G
Post by Olivier_G »
Well...
- Options in View>'High Zoom Quality' should apply to View and Fullscreen lite.
- Use delayed HQ should apply to View as well as Fullscreen lite (and should be moved to 'View' with 'High Zoom Quality' options).
- Browser>Preview>Use High Quality should apply to Preview only.
This can be done now (don't move "delayed HQ" if you don't want to change GUI) and shouldn't change because of the Fullscreens War. :D
It should be fixed now, because users may experience quality or performance issue with zooming... without really using the right option.
Olivier
Olivier_G
Post by Olivier_G »
Not completely fixed in RC2:
"Options in View>'High Zoom Quality' should apply to View and Fullscreen lite"
OK... except, that I can't get HQ in Fullscreen when zooming >100%, even with View>Enlarge=HQ.
"Use delayed HQ should apply to View as well as Fullscreen lite (and should be moved to 'View' with 'High Zoom Quality' options)"
Still no delayed HQ for normal View (maybe this should be postponed to 1.83... ?)
Olivier
Olivier_G wrote:Not completely fixed in RC2:
This 2 request in postponed please...
Olivier_G
Post by Olivier_G »
xnview wrote:This 2 request in postponed please...
Ok. No problem for me...
Olivier
