RC2: MP4 Hex-code in Preview pane?
Locked
ckit
Post by ckit »
When I double-click on a MP4-audio file it loads "foobar2000" and plays fine but in XnView the hex code for it is shown in the Preview pane!
This should not happen,
I've set "Audio files - Show in Preview" to disabled.
and "View - File List - Play Sound" is disabled.
BTW my MP4 files were created using Nero 6.6.0.16 or 6.6.0.18.
ckit
Post by ckit »
I have the same problem with XM-type MOD files.
ckit
Post by ckit »
Ok, I fixed it.
I needed to disable - "All Other Files - Show in Preview"
XnView needs to identify more audio files (MP3 and WAV aren't the only ones)
ckit wrote:Ok, I fixed it.
I can identify them only by extension. Do you have a list?
ckit
Post by ckit »
Audio File Types:
AAC,AC3,APE,FLA,FLAC,IT,M4A,MAC,MKA,MID,MIDI,MOD,MP+,MP2,MP3,MP4,MPC,MPP,MTM,OFR,OFS,OGG,OGM,PAC,PVA,RA,RMI,S3M,SHN,SID,SND,SPX,TTA,UMX,WAV,WMA,WV,XM
I'll add more as I remember them - there's lots.
marsh
Post by marsh »
ckit wrote:Audio File Types:
AAC,AC3,APE,MID,MIDI,MOD,MP+,MP3,MP4,MPC,MPP,OFR,OFS,OGG,OGM,PVA,RA,RMI,S3M,SND,SPX,TTA,WAV,WMA,XM
FLAC,SHN
ckit
Post by ckit »
Thanks marsh!
Just wait until we get to work on the FULL load of video file extensions :)
marsh
Post by marsh »
ckit wrote: Just wait until we get to work on the FULL load of video file extensions :)
And text extensions. :)
ckit
Post by ckit »
Nothing has been added in RC3.
Postphoned?
ckit wrote:Nothing has been added in RC3.
Postphoned?
I've added MP4, and some other extensions...
ckit
Post by ckit »
Ah sorry, you're correct I was a little too quick going through things this morning.
Thanks!
Dreamer
Post by Dreamer »
So can I close it?
ckit
Post by ckit »
Yes, you can close it.
Dreamer
Post by Dreamer »
OK, closed.
Locked
