xnview doesnt display .png with transparency correctl
Teal
Post by Teal »
heres the deal xnview displays png images like mspaint. :( the transparent part is blacked out,.
Re: xnview doesnt display .png with transparency correctl
Teal wrote:heres the deal xnview displays png images like mspaint. :( the transparent part is blacked out,.
Is it picture with colormap?
camelgrass
Post by camelgrass »
xnview wrote:Is it picture with colormap?
Transparent PNG's don't display correctly in my XnView either.
Not sure what you mean by "colormap" but here's an example of a PNG that won't display correctly http://yestech.com.au/female.png.
Cheers,
Marty
camelgrass
Sorry try this link ;).
8 BPP
:) Hello !
- "Colormap" means a picture maxi. 8 BPP (256-colour) for which you can display the palette from the Image Menu >> Edit colormap.
- With other colour-depths, this entry is blurred.
- Except I mistake, I don't think that currently XnView be able to support the transparency for pictures having a greater colour-depth…
- And -alas- the transparency is not supported at all for the icons *.ico
:mrgreen: Kind regards,
camelgrass wrote:Sorry try this link ;).
Ok, it's a 32bits. But the mask is only white or black.
Else you can view it by View/Show mask or Combine
Drahken
Post by Drahken »
This is the same problem I posted about a while back. Even when using the various mask options or the "compose with alpha" option, it doesn't show transparency properly on PNGs greater than 8bit.
