Moderators: Olivier_G, Dreamer, XnTriq, helmut, xnview
klaus2 wrote:This item was already raised and basically committed for the Todo-List;
see: viewtopic.php?t=3449&start=15
For me, with one additionaly option to the viewer fit modes xnview would be perfect:
- i want to define a favorite viewer window height (static)
- with "fit image to window height" the image height will adapt accordingly
image height = viewer height; the image width will change proportionally
- now, what i would like to have: that the viewer window width matches the resulting image width
viewer_width = new_image_width
In short:
Viewer window heigth: user defined; image height fits to that
Viewer window width: depends on calculated image size (limited by desktop width)
Vertically: image heigth = viewer height
Horizontally: viewer width = resulting image width
Pls note that doing so the left pos of the viewer should be kept as originally set by the user (no centering on the desktop wanted).
As far as i know that behaviour cannot be achieved with a combination of the available and activatable options.
klaus2 wrote:Yes, Pierre ..
xnview wrote:klaus2 wrote:Yes, Pierre ..
And what name can i use???
'Fit to window width, var. height'??
klaus2 wrote:Helmut,
no problem ... wating for responses
klaus2 wrote:Before using xnview, which is for me the most excellent viewer, i liked such that behaviour with acdsee 2 or 3 or irfanview. Maybe it could be helpful to have a kind of preview how that looks doing a short test with irfanview?
(i can tell the options, if needed)
klaus2 wrote:PS: please let the user decide ... i'm a user too
klaus2 wrote:many thanks for understanding and patience again
klaus2 wrote:I missed a symetric ""Fit image to window width, variable height" by intention, because a) one more request b) in my eyes: not useful (try to imagine the behaviour in practice, it does not really appear to make very much sense). It would be symetric, but ... hmm ... i guess you wouldn' find it elsewhere ..
But i'm happy that you immediately got that point
klaus2 wrote:PS: Maybe in the past i had not been able to express my desire understandable enough, so - additionally - what i could offer to you and Pierre is to send you a self written prog that exactly behaves like described (purely hobby driven, a pain <sigh>. - But better to See than to Read .. and maybe it might help to enforce a decision (Go or Nogo) ...). Simply tell me, i'll try to contribute as best as i can!
==== "Fit image to window height" might look like:
Image1 next ... Image 2 next .. Image3
I====Viewer window ===I I====Viewer window ===I I====Viewer window ===I
I XXXXXXXXXXXXXX I I XXXXXX I I XXXXXXXXXXXX I
I=====================I I=====================I I=====================I
==== "Fit image to window height, var. width" would look like
I=== Viewer ===I IViewerI IViewer win. I
IXXXXXXXXXXXXXXI IXXXXXXI IXXXXXXXXXXXXI
I==============I I======I I============I
klaus2 wrote:In short:
1. Viewer window heigth: user defined; image height fits to that
2. Viewer window width: depends on calculated image size (limited by desktop width)
Users browsing this forum: No registered users and 1 guest
