SE: Option to change LMB action on thumbnail
Dreamer
Post by Dreamer »
Suggestion for XnView Shell Extension.
Option to change LMB action on thumbnail to:
- view image/open in default program
- always open in XnView (also audio/video files)
- edit (image) (in default/custom editor)
- zoom in/out (double size)
- close context menu
- edit - open preview window (use mouse wheel to switch between images - selected or all in the current folder) - then also RMB should be available, so LMB could open image and RMB close window (and SE)
Edit:
Maybe, since you can make special effect (negative) on 'mouse over' now, you could add also custom action on 'mouse over':
- standard blue background
- negative
- switch between thumbnail and information (custom, e.g. EXIF/IPTC)
Feel free to suggest other actions...
ckit
Post by ckit »
I support this request!
Dreamer
Post by Dreamer »
More here - http://newsgroup.xnview.com/viewtopic.p ... highlight= .
Dreamer
Post by Dreamer »
Addition - also other options would be useful, any option that is / will be availible in Shell Extension, e.g.:
- Convert to JPG directly
- Set as wallpaper
- Resize
- Flip / Rotate
Some people need to do the same action quite often and very quickly and this would be very useful for them.
Dreamer
