REQ: Auto-Refresh improvement
ckit
Post by ckit »
Pierre, would it be possible to create an option (enable\disable) in XnView to automatically refresh the list after you rename a file. At the moment I have to keep pressing F5 each time to re-sort things.
Thanks.
Re: REQ: Auto-Refresh improvement
ckit wrote:Pierre, would it be possible to create an option (enable\disable) in XnView to automatically refresh the list after you rename a file. At the moment I have to keep pressing F5 each time to re-sort things.
You want to sort your files after a rename?
ckit
Post by ckit »
Automatically, yes.
darkfader
Post by darkfader »
I tried moving files to another directory from within XnView and it did not immediately refresh the thumbnail view.
