Conversion with subfolders
Didi
Post by Didi »
Is it possible to change the dpi of images which are diveded in several subfolders with only one command??
nconvert -quiet -out 100 -dpi JPEG target/*.jpg
I know the root directory but i didnt know the names of the subfolder in it. So I need an option like -r.
Re: nconvert subfolders
Didi wrote:Is it possible to change the dpi of images which are diveded in severall subfolders with only one command??
I'll add a -r option...
maxteo
interesting
Post by maxteo »
interesting, but this can be done with some scripts:
for exemple:
Create two files with Script with
*****************SCRIPT de lancement.bat *******************
Setlocal
set REPimages=C:\Sizer_img
set REPscripts=C:\Sizer
set REPnconvert=C:\Sizer\Nconvert-win
c:
cd /d %REPimages%
for /D %%R in (*.) do call %REPscripts%\Sizer_rep.bat "%%R"
Endlocal
*****************SCRIPT Sizer_rep.bat *******************
cd /d "%1"
nconvert ...... *.jpg ......
Echo répertoire "%1" traité
cd ..
Hurray! That will make a difference to nconvert, since this is often needed.
See also topic "Recurse subdirectories".
XeL
Post by XeL »
When will the -r option be available?
XeL wrote:When will the -r option be available?
I've just updated and browsed the command line options, but there's still no -r for recursing subdirs available.
I've added this to the Global Request & Suggestion list and will point Pierre to this feature request.
Andys
Post by Andys »
Temporary solution I use (WindowsXP) -
cmd file, from this thread - http://newsgroup.xnview.com/viewtopic.php?t=204
modified to look like this -
@for /R /D %%a in (*) do nconvert.exe <your_options_here> "%%a\*.*"
I added /D switch, it prevents running nconvert exe for each single file. Instead, it runs nconvert for each subdirectory (note the "\*.*" file mask at the end). Should be faster this way.
// EDIT
For me, previous sample didn't work when there were spaces in dir names.
Here's an update -
@for /R /D %%a in (*) do nconvert.exe <your_options_here> %%~sa\*.*
~s is a documented 'for' feature, it converts to short path
nget
Help with subdirectories
Post by nget »
I have several folders (400) in this structure:
\stock\#item_id#\foto\preview
where #item_id# is variable
i need to nconvert that jpg and save the result in his "preview" subfolder
Can someone help me with the script?
Thanks in advance!
nget
