"High Zoom Quality" in fullscreen?
Jackie
Post by Jackie »
is it possible to activate "High Zoom Quality" in fullscreen mode? On my system, I get ugly pixelinterpolations in fullscreen, whereas the option works fine for windowed mode. Is there a trick how to enable "High Zoom Quality" in fullscreen?
Btw, can I tell XNview always to open pictures in real fullscreenmode (i.e. no captions, bars, etc.) rather than windowed mode when I press enter?
cu,
Jackie
Re: "High Zoom Quality" in fullscreen?
Jackie wrote:is it possible to activate "High Zoom Quality" in fullscreen mode? On my system, I get ugly pixelinterpolations in fullscreen, whereas the option works fine for windowed mode. Is there a trick how to enable "High Zoom Quality" in fullscreen?
Do you have option/View/Zoom - Enlarge?
Take a look at option/general/Switch mode
VuDu
Post by VuDu »
both of those features are in the options screen. just search a bit ;)
Ad decus et ad libertatem nati sumus
Aut haec teneamus aut cum dignitate moriamur
Olivier_G
Post by Olivier_G »
xnview wrote:Do you have option/View/Zoom - Enlarge?
Pierre: remember that it doesn't work in 1.82 with Fullscreen lite, as we saw there...
Olivier
No, i use it for browser fullscreen too (if picture is smaller than window)
Jackie78
Post by Jackie78 »
what does fullscreen lite mean? It doesn't work for me with fullscreen when I enlarge pictures, you can clearly see it does not work.
Btw, I get the following error message when I start XNView:
"ncsecw.dll component not found" (or similar, it's in german language for me). What can I do to fix?
Thank you,
Jackie
VuDu
Post by VuDu »
It might be some error on you .ini file.
Go to the XnView folder, locate xnview.ini and rename it.
Restart XnView and see if you still have that error.
Don't forget renaming the .ini file will reset you preferences. ;)
Not called
:arrow: Jackie78
:) Hello !
- As far as I can see from "ScanBin", XnView doesn't call that DLL, as well as a direct call (13 are called) as an indirect call (6 are called).
Moreover, it doesn't exist here in my PC under Xp-Pro, and I've not your problem !
:mrgreen: VG
Jackie78 wrote:Hi,
Your picture is viewed larger than screen?
So remove Xecw.dll
Olivier_G
Post by Olivier_G »
xnview wrote:
Olivier_G wrote:Pierre: remember that it doesn't work in 1.82 with Fullscreen lite, as we saw there...
Well... I tried with all HQ enabled (HQ Enlarge and all) and a small image is just pixelized when enlarged in Browser fullscreen (Zoom >100% +image smaller than screen)... :(
Olivier
Yes, right, but a large picture in 'fit large' for example, use the HQ.
Currently there is no HQ in enlarge zoom.
Danny
Post by Danny »
xnview wrote:Yes, right, but a large picture in 'fit large' for example, use the HQ.
Does not work for me either, as mentioned here: http://newsgroup.xnview.com/viewtopic.php?t=5095
I can see a clear difference between viewer and fullscreen mode.
Hum, could you send me a example, screen resolution used?
Danny
Post by Danny »
xnview wrote:Hum, could you send me an example, screen resolution used?
Sure. Take a look at this one for example:
In fullscreen mode the letters look all scrambled while in the viewer they're smoothed out. Dektop resolution is 1280x960.
I have no problem with it. So, how do you start the fullscreen? F11?
Do you have option/View/Zoom quality/Reduce?
