DX: 'Create' toolbar button (with sub-items)
Dreamer
Post by Dreamer »
'Create' toolbar button (with sub-items)...
Edit: Main button could perform last used action.
And you fire ?????
:) Hello !
- Indeed, as much more buttons as you want, I agree and support…
- But please, tell me which actual ones you would fire ?
- With the actual system using a “frozen” single bitmap, there are only two solutions :
1. Fire existing buttons to recover their locations on the bitmap - and update all the skins-, {*}
2. Increase the bitmap at size (more icons) - and remake all the skins:(
• I've proposed other ways for a while, including the addition of extra-tool-bar(s) as plugins, quite unsuccessfully till today…
- It should be coherent to support such requests and ideas while it's obvious that much more buttons are needed, and cannot be added in the practice…
{*} In 1.82.2, not even all skins have been updated about the new browser small bar… Mine are.
:mrgreen: KR
Dreamer
Re: And you fire ?????
Post by Dreamer »
Maybe we could use "deluxe system" (of buttons) - Pierre?
ZoNi
Post by ZoNi »
I need wallpaper button, with dropdown (set center, fit, best fit, etc...)
SeaMaiden
Post by SeaMaiden »
As long as Toolbar 4 (Dominique Clément) is updated or remade, it does not matter to me. That's the only one I use.
Windows 11 (64-bit), Android 12, XnViewMP 1.5.0, XnResize 1.10, XnShell 4.16
** XnView ROCKS **
not the skin---
—> SeaMaiden
:D Hello T. !
• That is lame here is not the skin-thing, but the basic original tool-bar system itself, which is indeed very limited and impractical when one wishes to add buttons…
- Even remaking a 50-icon skin should not solve the issue definitely…
… since soon or later some users will request more than 50 icons for more than 50 internal commands… :wink:
- It's quite possible to have better; for instance, in Total Commander you can set as so numerous icons as you wish, as several bars -but only one can be displayed at the same time, and each one can call any other-; any icon of any size can be used for any button, as *.ICO, from an ICL, DLL, EXE etc… I can't imagine that programme having a "frozen" tool bar limited to 33 buttons - like XnView currently-, or even a few more, it has legion of internal commands (documented), and XnView has a lot too (not documented yet?)…
:mrgreen: I pay my respects to you,
Xyzzy
Re: DX: 'Create' toolbar button (with sub-items)
Post by Xyzzy »
Dreamer wrote:'Create' toolbar button (with sub-items)...
Because main menu cannot be disabled, you'd always get the menu twice, once in main menu and once on a button- working exactly the same way. Seems useless redundancy.
X.
Dreamer
Post by Dreamer »
X.
There could be an option to disable menu in the future and it could be more useful with another idea...
JohnFredC
Post by JohnFredC »
2Clo
Greetings!
Have you tried the SpeedCommander 11 toolbar system? It works almost exactly like Microsoft Office, even provides an icon editor "inline"...
The DOpus toolbar system works well, too.
I really like the TC ability to drag files and folders to the toolbar and have them automatically become drop points.
A combination of the TC approach with the SC 11 approach would be fantastic in XNView.
John
A way to find…
—> JohnFredC
:) Hello John !
- I may admit I didn't, first 'cause SC is not really localizable yet, so I avoid it like the plague, and 2nd. 'cause I'm neither an intensive user of M$ Office, nor a fanatic of its icons system…
- I do too ! IMHO, it's the best tool-bar system - at least among those I know -, even if it has still some lacunæ like a single icon-size for bar #1 and all sub-bars, and other minor thingumabobs in the same painting…
• For instance : unable to extract ¦ use icons from a multi-page TIFF containing only icons, much more simpler to create - with XnView - than ICLs…
Image Maybe… Could you show us a more precise approach ? Fake dialogues welcome !
:mrgreen: Kind regards,
ouistiti
Post by ouistiti »
I agree totally, and I would be glad too to know more about your ideas for tool-bars in XnView !
Paul
1,77245385090552...
JohnFredC
Post by JohnFredC »
2Clo
Just download SpeedCommander and check it out! There is a 30 day evaluation period.
John
