"Clean Metadata" to Batch convert
Dreamer
Post by Dreamer »
Suggestion - add option "Clean Metadata" (from menu) to Batch convert - Transformations:
[x] Optimize (Huffman table)
Remove
[ ] Comment
[ ] EXIF
[x] EXIF thumbnail
[ ] IPTC
[ ] All others 'APP' makers
It's a useful feature but a bit hidden - several images can be selected and this option can be used, but most users don't know about it probably.
Since it already exists, it should be easy to implement IMO.
ckit
Post by ckit »
I support this request.
marsh
Post by marsh »
I support. And Nconvert also. It already has "-rmeta" switch, but it is not lossless.
ckv
Post by ckv »
Great idea. :D
ckit wrote:I support this request.
Ok, but is it really needed because clean works as batch...
Dreamer
Post by Dreamer »
Definitely, IMO...
Useful feature is useless when it's hidden.
