Please add a colored highlight to active tab, for a clear and easy to see indication of the active tab. So users can see and work more efficiently in a multitab environment. Thanks.
Sample before and after comparison of the concept:
[ with 3D effect on active tab ]
[ no 3D effect on active tab ]
- I support ! Though I don't use the XP-themes, the active tab is difficult to distinguish too…
- To complete your request, I'ld wish that the highlighting colour be configurable…
KR
Tzunami, thank you for your suggestion and sample. The idea of colouring the tabs for easier recognition is o.k.. But as you can see in your sample, the visual 3D impression is lost when colouring the whole tab. So in no case the whole tab must be coloured. What we could do is colour the very top of the tab, similar to FireFox.
helmut wrote:Tzunami, thank you for your suggestion and sample. The idea of colouring the tabs for easier recognition is o.k.. But as you can see in your sample, the visual 3D impression is lost when colouring the whole tab. So in no case the whole tab must be coloured. What we could do is colour the very top of the tab, similar to FireFox.
Or maybe the color of the text. But i actually think it's fine the way it is.
OK, so I added a 3D an no 3D versions for you to compare. I tend to like the no 3D version a bit more [clearer to the eyes to me].
I would like to see colour highlighting for both the Active and Inactive tabs!
You know TsunamiZ, you could just download the latest beta version and see yourself or at least read the beta changes log, instead of posting in all the topics asking progress reports.
And to answer your question (Cause I like your requests)... Yes this feature have been implemented in the 1.90 beta. But now please go at least to read the beta changes log.
XnView Tweak UI - Tool to customize your XnView beyond the regular XnView options. UI-less Settings - Documentation of all the hidden settings in XnView. XFAM - Tool to create and customize XnView file associations.
No we're past that, version 1.90 is now at Beta 1.
No, it won't crash your system or at least others haven't reported anything like that and neither have I.
There is no file corruption or deleted files.
I recommend installing XnView 1.90 beta 1 into a seperate folder if you're worried about it's stability and keep XnView 1.82.4 final installed.
Getting back to the topic:
I would like to see inactive tabs have "light creme" colour and active tabs can keep the "light blue" colour.
TsunamiZ wrote:well if it was beta, i would feel safer to try it. but it's still alpha stage
Yes the links where pointing to older alpha topic. Fixed now.
