ICL files crash, feature requests
patrickang
First of all, thanks for a great product.
Found a bug (?):
- When viewing .ICL file, I get the Windows blue screen (exception).
Feature requests:
- In the "Multiple File Convert" dialog, the Directory is always blank when the dialog is showed. Can it retain the last used directory?
- Can the applications listed in the "Open with" popup be renamed? (eg. instead of Mspaint, Microsoft Paint)
- When viewing .ICO files, I get a black background. Can I change this? or use the background color (like in transparent GIFs)
Thanks again!
System: Windows 98 SE; XnView 1.68.1
Found a bug (?):
Feature requests:
Thanks again!
Re: ICL files crash, feature requests
There was a problem with ICL files in previous versions of XnView, but this has been fixed in Version 1.68 (or even an earlier version).patrickang wrote:... Found a bug (?):
- When viewing .ICL file, I get the Windows blue screen (exception). ...
Could please mail a sample Icon Library file to Pierre or upload it onto a webserver and post a link to the ICL file here?
patrickang
patrickang
You have sent a sample to Pierre, so he knows now and will fix the problem occasionally.patrickang wrote: Sorry I wasn't clear. What I meant was the files opened fine with v1.66 but raised exceptions with v1.68.x.
But after opening a couple more ICLs with v1.66, I got the blue screen too.
patrickang
patrickang
It crashes when:xnview wrote: When do you have the crash?
I've tested on windows 98SE, and no problem![]()
1. I use the Browser (thumbnail viewer) to view a folder containing the ICL file
2. I tried to view the ICL file and navigate through the icons using the Next/Prev page buttons.
Both crashes after a few (10?) seconds. Tried it on 2 different computers (office & home), both running Win98SE and same results.
Sam
old, old trouble
System: Windows 98 SE; XnView 1.70.4
Open in Browser (thumbnail or detail mode) icl file -> Windows blue screen.
Example: http://zapatopi.net/icon/archaeologicons.zip
Heading of a file:
------------ Archaeologicons.icl ----------------------
4D 5A 00 00-00 00 00 00-00 00 00 00-00 00 00 00 MZ
00 00 00 00-00 00 00 00-00 00 00 00-00 00 00 00
00 00 00 00-00 00 00 00-00 00 00 00-80 00 00 00 À
00 00 00 00-00 00 00 00-00 00 00 00-00 00 49 4D IM
4E 45 00 00-00 00 00 00-00 00 00 00-00 00 00 00 NE
00 00 40 00-40 00 8C 07-00 00 00 00-00 00 00 00 @ @ Ì
Heading of a file:
Re: old, old trouble
I'll test. The problem occurs in 98 & Xp?
