Option to always show browser tab?
TsunamiZ
Is there an option to always show browser tab [regardless of how XnView is started]? Thanks.
Re: Option to always show browser tab?
For example, if you start with windows explorer?TsunamiZ wrote:Is there an option to always show browser tab [regardless of how XnView is started]? Thanks.
No spot---
—> TsunamiZ
Hello !
- I didn't see any spot of such an option yet, but it could be useful, so I support if you request it !
—> Pierre
Hello !
- What about simply an extra INI-entry for this ? It should lighten the job…
Kind regards,
—> Pierre
TsunamiZ
Yeah, like if XnView is started by opening image files in Windows Explorer.xnview wrote:For example, if you start with windows explorer?TsunamiZ wrote:Is there an option to always show browser tab [regardless of how XnView is started]? Thanks.
Currently i don't open the browser to be quick...TsunamiZ wrote:Yeah, like if XnView is started by opening image files in Windows Explorer.xnview wrote:For example, if you start with windows explorer?TsunamiZ wrote:Is there an option to always show browser tab [regardless of how XnView is started]? Thanks.
Only the TAB !
- Do you mean that simply to show the tab-button (just a command) needs to have the browser open in another thread ?
- I can mistake, but I don't think so…
TsunamiZ
Re: Only the TAB !
I simply mean to be able to have the browser tab always there. In certain cases, XnView opens without a browser tab [even if specified].
Re: Only the TAB !
Yes for a quick startTsunamiZ wrote:I simply mean to be able to have the browser tab always there. In certain cases, XnView opens without a browser tab [even if specified].
TsunamiZ
Re: Only the TAB !
But it would be nice for users to have an option to always have browser tab open. And have that tab be browsing the folder the file was opened.xnview wrote:Yes for a quick startTsunamiZ wrote:I simply mean to be able to have the browser tab always there. In certain cases, XnView opens without a browser tab [even if specified].
Re: Only the TAB !
But if press entre, the browser is opened... no?TsunamiZ wrote:But it would be nice for users to have an option to always have browser tab open. And have that tab be browsing the folder the file was opened.xnview wrote:Yes for a quick startTsunamiZ wrote:I simply mean to be able to have the browser tab always there. In certain cases, XnView opens without a browser tab [even if specified].
TsunamiZ
Re: Only the TAB !
Yes, but it's inconvenient if the user already specified XnView to always start with browser tab and it doesn't always do that.xnview wrote:But if press entre, the browser is opened... no?TsunamiZ wrote:But it would be nice for users to have an option to always have browser tab open. And have that tab be browsing the folder the file was opened.xnview wrote: Yes for a quick start
