Taskbar hiding titlebar
Danny
If you put you windows taskbar at the top of the screen and view an image with XNView, it's titlebar will be hidden underneath the taskbar. There's as much free space at the bottom of the screen as the taskbar would occupy so i think it's a positioning problem.
Hide ???
• What about "Hide automatically" for the task-bar ? I've a couple of "Quick launch" Win bars (at top) and the task-bar (at bottom) set such as, no problem… XnView stays on top, even as "Normal" (adjustable) size (I use it rarely like this).
Re: Taskbar hiding titlebar
When you dbl-click on a picture in windows explorer??Danny wrote:If you put you windows taskbar at the top of the screen and view an image with XNView, it's titlebar will be hidden underneath the taskbar. There's as much free space at the bottom of the screen as the taskbar would occupy so i think it's a positioning problem.
Danny
Re: Hide ???
That'd be merely a workaround and i don't like using that setting.Clo wrote:• What about "Hide automatically" for the task-bar ?
Yes, exactly.xnview wrote:When you dbl-click on a picture in windows explorer??
Re: Hide ???
Strange i have checked and the window has good top-left position...Danny wrote:Yes, exactly.xnview wrote:When you dbl-click on a picture in windows explorer??
Danny
Re: Hide ???
Well, it probably depends on my additional window settings:xnview wrote:Strange i have checked and the window has good top-left position...
- auto image size: fit image to desktop, large only
- maximize view when open enabled
- remember position enabled
- different position for browser/viewer enabled
Also make sure you open an image higher than your desktop resolution. Still the same?
Re: Hide ???
Could you send me your .ini please?Danny wrote:Well, it probably depends on my additional window settings:xnview wrote:Strange i have checked and the window has good top-left position...
Danny
Danny
marsh
Re: Hide ???
I could reproduce this with 1.82.4. This seems to be fixed in 1.90 Beta 3. Do you confirm, Danny?Danny wrote:Well, it probably depends on my additional window settings:
Danny
Re: Hide ???
Yes, works over here. Thanks.helmut wrote:I could reproduce this with 1.82.4. This seems to be fixed in 1.90 Beta 3. Do you confirm, Danny?
Get the bugs fixed, THEN start adding features. It sucks, but someone has to do it.
