Two monitors usage
jablan
Two monitors usage
Post by jablan »
Image only partially visible in this condition:
I use two displays with different resolutions (dual-head graphics card):
primary uses 1024x768
secondary 1280x1024
I use XnView on secondary display (one with bigger resolution).
When I try to view an image, only top part of the image gets displayed (I guess top 768 pixels). This is best experienced when you display and then zoom in a small picture step by step. At one point bottom part of the picture isn't visible anymore.
Here's a screenshot
Re: Two monitors usage
jablan wrote:Image only partially visible in this condition:
secondary 1280x1024
Here's a screenshot
Ok, i'll check
