I use also photofiltre studio a support for pfi file will be really welcomed.
browse photoshop brush folder(.abr)+read pfi(photofiltre)
fotocomics
Re: browse photoshop brush folder(.abr)+read pfi(photofiltre
Could you send me some samples?fotocomics wrote:will be beatiful to have the chance to browse unistalled Photoshop brushes
... even more to convert them (in .png and gbr)
fotocomics
I can send you original brushes from CS 2 and all kind of other brushes zipped files,...in the while here some (random) link for free download
http://www.deviantart.com/deviation/10351757/
http://www.deviantart.com/deviation/528778/
http://shad0w-gfx.deviantart.com/
Note "old" brush set,for photoshop 7 usually work also in the newest photoshop CS2
" New" brush set for CS and CS 2 usuallydo not work on previous Photoshop release (so something must have changed in the .abr file format from photoshop7 to cs)
You can send me files at webmaster-nospam@xnview-nospam.com (remove -nospam)fotocomics wrote:sure.. but how
.. I don't see any option to send allegates to this forum
