XnView is flickering when switching modes
Eddie1506
Post by Eddie1506 »
Every time I want to switch modes (with any button and with any action), XnView screen flickers a few times and then loads.
It also happens when opening images from explorer in fullscreen view. At first, the image is shrunk and there is a large gray horizontal bar below it, and after the few flickers, it shows correctly.
Now, this is not some sirious issue, but it's very irritating.
Anyone knows how to fix it?
Re: XnView is flickering when switching modes
Eddie1506 wrote:Every time I want to switch modes (with any button and with any action), XnView screen flickers a few times and then loads.
Which options do you have in option/general/Switch modes? And how do you switch modes?
Eddie1506
Post by Eddie1506 »
I have double click setup up as Browser <> Viewer and middle and enter as Browser <> Fullscreen | Viewer <> Fullscreen
I always change modes with double click, from explorer or from XnView directly.
Eddie1506 wrote:I have double click setup up as Browser <> Viewer and middle and enter as Browser <> Fullscreen | Viewer <> Fullscreen
When you use F11, you don't have flickering?
Eddie1506
Post by Eddie1506 »
I do, but less then before.
Eddie1506 wrote:I do, but less then before.
But you have flickering too? Could you try to disabled option/Browser/Thumbnail/Use high quality and try again F11?
Eddie1506
Post by Eddie1506 »
It still doesn't help... :(
Eddie1506 wrote:It still doesn't help... :(
And disabled all checkbox in option/View/High zoom quality?
Post by Guest »
Then it's ok, but in that case, xnview occasionally crashes.
Ok, but you have a crash when?
Eddie1506
Post by Eddie1506 »
I open the pic from Windows Explorer in view mode and then it crashes when I doubleclick on the image to open the browser.
Eddie1506 wrote:I open the pic from Windows Explorer in view mode and then it crashes when I doubleclick on the image to open the browser.
Hum, perhaps you have a bad file in this folder? If you open the folder in xnview?
Eddie1506
Post by Eddie1506 »
No bad files... It happens regardless what folder I choose.
Someone has the same problem?
Hardware ?
—> Pierre
:) Hello Pierre !
• No problem here in the case, but Eddie1506 didn't say anything about his hardware configuration…
- This could be related to a graphic-card¦its driver¦the amount of video-RAM¦the amount of global free RAM¦Which OS ?…
:mrgreen: Kind regards,
