Rename auto select name NOT extension...
TsunamiZ
Post by TsunamiZ »
Any chance rename can auto select just the file name and NOT extension? It would save a lot of time editing file names. Thanks.
Re: Rename auto select name NOT extension...
TsunamiZ wrote:Any chance rename can auto select just the file name and NOT extension? It would save a lot of time editing file names. Thanks.
In the browser?
TsunamiZ
Post by TsunamiZ »
yeah
Like in TC---
—> Pierre
:) In Total Commander, this is done via 2 extra-INI entries, one to simply enable¦disable that feature :
InplaceRename=1
Enable / disable inplace renaming when clicking twice on a name (1/0)
- The other to choose if the whole name + ext. or only the name is highlighted to rename :
RenameSelOnlyName=1¦0
"1" : Selects only the name in the inplace-rename field.
"0" : Selects the name and the extension.
- So, it might be so simple to add in that way…;)
• Simpler and better :
InplaceRename = (flag)
Image0 : Disabled
Image1 : Show & select “Name + extension”
Image2 : Show “Name” only
Image3 : Select “Extension” only
:D What do you think ?
:mrgreen: KR
Dreamer
Post by Dreamer »
I'd prefer same dialog as in Viewer, by default, option isn't necessary IMO.
Not inplace---
—> Dreamer
:D Hello !
- If you prefer a dialogue, then this no longer an “Inplace Rename”, and the start-poster TsunamiZ is talking about this, it seems ? Image
:mrgreen: KR
TsunamiZ
Post by TsunamiZ »
just have rename auto select just the file name, not extension...
An option is needed---
—> TsunamiZ
:) Hi !
- I guess I got you. But to obtain this, an option is needed anyway, because all users don't wish the Inplace Rename like you ;)
- So, forging ahead, why not all capabilities, allowing to satisfy everybody ?
:mrgreen: KR
Dreamer
Post by Dreamer »
I think more important is to have selected just filename, not extension. Dialog would be easier to implement maybe, since it already exists in Viewer.
Not the wish
:D Yes, but again : this is no longer an “Inplace Rename” !
8) Let's wait for know the Pierre's opinion…
:mrgreen: KR
TsunamiZ
Post by TsunamiZ »
any progress?
foxyshadis
Post by foxyshadis »
It's been in all the 1.90 betas.
