No thumbnails for MPEG4 (.mp4)
Sam Simpson
Post by Sam Simpson »
I'm using XnView 1.82.4 (Windows XP SP1) and have noticed that for movie files encoded with MPEG4 Simple Profile XnView doesn't build thumbnails although it plays them without any problems. Would be glad to know if anybody has the same problem or better, knows how to solve this....
Dreamer
Re: No thumbnails for MPEG4 (.mp4)
Post by Dreamer »
Sam Simpson wrote:I'm using XnView 1.82.4 (Windows XP SP1) and have noticed that for movie files encoded with MPEG4 Simple Profile XnView doesn't build thumbnails although it plays them without any problems. Would be glad to know if anybody has the same problem or better, knows how to solve this....
Try to rename it to .avi.
Sam Simpson
Thanks, it works! Although it's not exactly what i wanted, but thumbnails are here) maybe there is a way to solve it without renaming? i need extension .mp4^)
Dreamer
Post by Dreamer »
Sam Simpson wrote:Thanks, it works! Although it's not exactly what i wanted, but thumbnails are here) maybe there is a way to solve it without renaming? i need extension .mp4^)
Options > Browser > File list > Recognize only by extension.
Anyway, few file types should be added to xnview as videos, mp4, 3gp, divx?...
Sam Simpson
Yea, i think it would be the best solution for the problem. It was already requested as "One Easy Option to cripple XnView's access to ALL video file types (avi, divx, mpg. mov) I want it so XnView treats the file as though it has no extension at all" by Ckit. Changing "Recognise.." doesn't do what it should do. Thanks for help
It's for picture not video
