It is possible to copy full path and filename of image in browser view by pressing Ctrl-C, but if image is viewed there isn't a way to do this (only copy twice names from Properties window).
What do you think about copying image path to clipboard by shortcut like ctrl+alt+c?
Copying full path adn image filename to clipboard
Re: Copying full path adn image filename to clipboard
I can do it in my file manager, I have changed it to the same shortcut, so it must be good.Tempuser wrote:It is possible to copy full path and filename of image in browser view by pressing Ctrl-C, but if image is viewed there isn't a way to do this (only copy twice names from Properties window).
Anyway, already requested for - Automatic contrast - Ctrl+Alt+C.
Exists… Existed…
• In the browser only, use <Shift+L> to create a very complete file listing, even for a single file. This calls a dialogue.
- This is also a local-menu entry when you right-click a selected thumb-nail, and in the “Create” menu of the menus bar.
- However, that no longer exists from the “View” mode, as far as I see…
- So, just copy the file-name and¦or¦ its path to the clipboard should be useful many times, like this exists i.e. in Total Commander file manager…
