Menu font on dark backgrounds
Dreamer
Post by Dreamer »
XnView:
Other programs:
Re: Menu font on dark backgrounds
Uhh, not much to see. Must be hard to select a specific menu item ;-)
Just an idea: What happens if you change the state of the setting: "Use XP style menus" in "Tools > Options > General > Startup"?
Dreamer
Post by Dreamer »
helmut wrote:Uhh, not much to see. Must be hard to select a specific menu item ;-)
OK, helped, thanks, but it should be fixed though. Anyway, it's not so important now.
