With mouse, slideshow (Ctrl+L) advances to next picture in steps of two:
1, 3, 5, 7... (skipping files 2, 4, 6).
Advancing to next picture works normally with keyboard.
(This also occurs with slide.exe)
Slideshow goes forward in steps of two.
marsh
Re: Slideshow goes forward in steps of two.
only with slide.exe?marsh wrote:With mouse, slideshow (Ctrl+L) advances to next picture in steps of two:
marsh
Both slideshow and slide.exe. v.1.82.4xnview wrote:only with slide.exe?marsh wrote:With mouse, slideshow (Ctrl+L) advances to next picture in steps of two:
Update: it only occurs with transition effects turned off.
Could you tell me which settings do you have? I can't reproduce...marsh wrote:Both slideshow and slide.exe. v.1.82.4xnview wrote:only with slide.exe?marsh wrote:With mouse, slideshow (Ctrl+L) advances to next picture in steps of two:
marsh
Settings:xnview wrote:Could you tell me which settings do you have? I can't reproduce...marsh wrote:Both slideshow and slide.exe. v.1.82.4xnview wrote: only with slide.exe?
[x]Use keyboard/mouse
[x]Fullscreen
[ ]Use Random Order
[ ]Loop
Use Transition Effects [None] *This is problem setting for me*
More Options:
[ ]Stretch Small Pictures
[ ]Stretch Small Videos
[ ]Use High Quality
[x]Center Window
[x]No Title bar
[x]Use Gamma setting in exe/scr
[ ]Suppress read errors
[ ]Save relative paths in SLD
-All caches off.
Using right button (forward) skips files, LMB does not, keys do not.
marsh
