I just downloated xnview for a trial and my initial reaction is positive. For example, I like being able to see the EXIF date with the thumbnails.
But I have been unable to sort or rename sorted by EXIF date (shooting date/time). This is helpful when shooting with two cameras and images from one needs some post-processing... which changes the file modified date. Now I want to sort them in the AS-SHOT order (camera clocks were set very close).
Suggestions? Perhaps renaming files using EXIF dates (although I don't know how), sorting, then renaming again in numeric form I finally want?
___ Olin (Iowa, USA)
Sort by EXIF date?
Re: Sort by EXIF date?
What version do you have? Try 1.82.4.Olin Genere wrote:...Perhaps renaming files using EXIF dates (although I don't know how)...
Then select files, press F2, Sort by > EXIF date and Insert>>...
Also check this.
Dreamer
Thank you! Things are easy if you know where to look... and where to look seems so obvious when someone points them out that it's almost embarrassing. <|=o)
It is just a little bit slow, but very much faster than doing it the hard way (manually)!!
___ Olin
___ Olin
