Setup plugin Adobe 8bf - Adobe Camera RAW 3.4?
infokeeper
Post by infokeeper »
That is possible? Setup plugin Adobe 8bf - Adobe Camera RAW 3.4?
Re: Setup plugin Adobe 8bf - Adobe Camera RAW 3.4?
infokeeper wrote:That is possible? Setup plugin Adobe 8bf - Adobe Camera RAW 3.4?
I don't know, i think that 8bf format has changed...
infokeeper
ACR plugin
unfortunately :(
I have Nikon D50 and don't want use Photoshop, because it is comercial.
I use your soft (XnView) because it is free and useful(all that is required or almost all :) But raw converter like Adobe Camera RAW missed... I wish setup ACR in XnView, but in dot't work :(
What advise?
Re: ACR plugin
infokeeper wrote:unfortunately :(
What advise?
ACR is free?
infokeeper
ACR
I don't know, please read this link
http://www.adobe.com/support/downloads/ ... ftpID=3364
Maybe if you read Adobe End-User License Agreement be distinctly.
Compatibilty, there I find:
"The Camera Raw 3.4 plug-in is not compatible with versions of Photoshop earlier than Photoshop CS2 or versions of Photoshop Elements earlier than Photoshop Elements 3.0"
P.S. Sorry, I bad know english
Re: ACR
infokeeper wrote: "The Camera Raw 3.4 plug-in is not compatible with versions of Photoshop earlier than Photoshop CS2 or versions of Photoshop Elements earlier than Photoshop Elements 3.0"
Ok, so not compatible with xnview :-(
infokeeper
ACR
This can be possible change?
Make XnViewer be compatible with new adobe plugin format?
Re: ACR
infokeeper wrote:This can be possible change?
The problem is that Adobe don't put specification for public :-(
JohnLakkas
ACR
Post by JohnLakkas »
I don’t thing that ACR (Adobe Camera Raw) is free. It’s the best/most used Raw Converter among photographers (OpenRAW organization survey). And it can be used only in CS2 (not CS etc) so it is quite obvious that it isn’t free. Adobe is probably making a lot of money only from their RAW handling software witch is a strong force to make you buy Photoshop (especially for pros).
Moderator & Librarian
Re: ACR plugin
Wikipedia – Adobe Photoshop wrote:The latest version comes with Adobe Camera RAW, a plugin developed by Thomas Knoll which can read several RAW file formats from various digital cameras and import them directly into Photoshop. A preliminary version of the RAW plugin was also available for Photoshop 7.0.1 as a $99 USD optional purchase.
