Thumbnail AI
mamole
Thumbnail AI
Post by mamole »
Hello to all.
Use version 1,82 and I cannot visualize miniatures AI of Marinates Ilustrator.
So that it can be?
Thank you very much and pardon by my ingles.
Post by Guest »
Pardon, I meant Adobe ilustrate
Thank.
Moderator & Librarian
* helmut wrote:XnView is intended for working with raster graphic files, that is image files which consist of pixels. Apart from this, XnView also supports some vector formats using GhostScript, e.g.:
- AI (Adobe Illustrator, not all subformats)
- PDF (Adobe Portable Document Format)
- PS (Postscript)
- EPS (Encapsulated Postscript)
GhostScript allows for printing and displaying vector graphics and converting these to raster graphic files.
Please note:
- Only reading these formats is supported.
- For these formats thumbnails are not displayed because of performance reasons.
- For AI files not all subformats are supported
- For CAD vector files, there's a special plug-in available, see topic "How to view .dwg files?"
Post by Guest »
Thank you very much by the aid.
A greeting.
Thank you, XnTriq, for collecting the right infos and providing links. :-)
Thank you, XnTriq, for collecting the right info and providing links. :-)
helmut wrote:Thank you, XnTriq, for collecting the right info and providing links. :-)
Oh yes, and you will never thank me enough for it. :P :wink:
