Moderators: helmut , xnview
tom*de
Posts: 40 Joined: Wed Mar 22, 2006 1:08 pm
Post
by tom*de » Wed Jun 14, 2006 9:22 am
How can I put easy a sign or a fixed text on all my pictures... i.g. my initials.
Rather transparent than very striking, like a watermark.
Thanks Tom*
Posts: 47031 Joined: Mon Oct 13, 2003 7:31 am
Post
by xnview » Wed Jun 14, 2006 9:24 am
tom*de wrote: How can I put easy a sign or a fixed text on all my pictures... i.g. my initials.
You can add text in batch convert
tom*de
Post
by tom*de » Wed Jun 14, 2006 9:52 am
Oh, yes. This works fine, thanks.
For a professional outlook I have two ideas:
1. Is it possible to make the text-stamp "a little bit" transparent , i.g. 50%?
2. Could xnview automaticly use a similar color for the text like the color of the picture has on this area? (i.g. light blue text on dark blue sky)
Tom*
Dreamer
Posts: 4608 Joined: Sun Jul 25, 2004 9:08 pm
Post
by Dreamer » Wed Jun 14, 2006 5:28 pm
tom*de wrote: Oh, yes. This works fine, thanks.
Tom*
1. I think this is already possible..
Dreamer
tom*de
Post
by tom*de » Fri Jun 16, 2006 9:05 am
I could define textcolor and textbackround, but I didn't found a way to make the inserted text transparent.
Any helps? Thanks Tom*
Dreamer
Post
by Dreamer » Wed Jun 21, 2006 3:39 pm
Probably you mean Batch convert, it is possible only in Viewer > Shift+T > Opacity.
Dreamer
tom*de
Post
by tom*de » Thu Jun 22, 2006 8:42 am
Dreamer wrote: Probably you mean Batch convert, it is possible only in Viewer > Shift+T > Opacity.
- In Batch convert STRG-U Opacity is not available, (not yet?)
- it's also a pity that the Batch convert settings are not saved.
Dreamer
Post
by Dreamer » Thu Jun 22, 2006 1:27 pm
tom*de wrote: - it's also a pity that the Batch convert settings are not saved.
You can save it as Script.
Dreamer
tom*de
Post
by tom*de » Sun Jun 25, 2006 7:10 pm
Yes it works fine. .. thus only a desire remains:
How can I make the inserted text a little bit transparent or/and set similarly the background colour?
Dreamer
Post
by Dreamer » Sun Jun 25, 2006 11:35 pm
As I said, it is possible only in Viewer > Shift+T > Opacity, Text back colour. It is not possible in batch convert (yet).
Dreamer
tom*de
Post
by tom*de » Mon Jun 26, 2006 10:43 am
Dreamer wrote: It is not possible in batch convert (yet).
Thank you, Dreamer. Thus this topic is correctly here in "Requests & Suggestions." I'm looking forward...
Dreamer
Post
by Dreamer » Mon Jun 26, 2006 11:55 pm
tom*de wrote: Dreamer wrote: It is not possible in batch convert (yet).
You're welcome.
I'm waiting for this option (opacity and outline) for fullscreen information too, so maybe it could be added also there now...
Dreamer
Dennis S.
Post
by Dennis S. » Mon Jul 17, 2006 3:31 pm
it would be nice to size the text in percent!
