exclude format ico and icl
R160m3605
Post by R160m3605 »
Does the possibility of esclure exist and therefore not to see determined formed as ico and icl? Thanks!
Re: exclude format ico and icl
R160m3605 wrote:Does the possibility of esclure exist and therefore not to see determined formed as ico and icl? Thanks!
Yes, in Options/Browser/Items displayed
Dreamer
Post by Dreamer »
No request, so moved to General Support.
Dreamer
Add, no exclude…
—> Pierre
:) Hello Pierre !
• Hum… I far as I see, this dialogue is designed to ADD¦IMPOSE the display of certain formats, but there is not any EXCLUSION feature !
• This could work in such a way, for instance, whether we'ld have the field for custom formats with a syntax like :
EPS EPSF PS PDF PPS WMV MOV MAX SWF ECW | ICO ICL
where all extension before the pipe | are imposed, while the ones forward the pipe (so, at right) are excluded
• I posted several messages already proposing such a syntax for various issues, but you didn't tell me if it can be used (or implemented) in XnView.
- It's very handy and useful, we have it in T.C., it solves many problems, either from the Options pages, or from extra-INI entries …
:mrgreen: KR
Dreamer
Re: Add, no exclude…
Post by Dreamer »
Clo wrote:• Hum… I far as I see, this dialogue is designed to ADD¦IMPOSE the display of certain formats, but there is not any EXCLUSION feature !
It is, you can mark/unmark checkboxes next to "Custom files (*)" to include/exclude.
Dreamer
Coal-juice !
:) Hello !
• This is totally unclear!
1. That dialogue can acts also for the View mode, since it has a column for this, so it's badly located currently.
2. When the Custom files box is ticked, nothing shows obviously that the types non-stated in the field are excluded !
3. There is an inconsistency with the other Option "Show all types -or so-" elsewhere…
- I already attempted to highlight this a long while ago, unsuccessfully…
{ Maybe ought I to learn Chinese to be understood here ? :P }
:mrgreen: KR
ouistiti
Post by ouistiti »
…This is totally unclear!
- I agree ! Currently, one can EITHER include OR exclude file-types, but not both !
And this is not explained on the dialogue.
- A syntax like Clo shows above should be much better, it exists in Total Commander and works fine. It saves an extra field for "Exclude"
At least, a second field could do the trick, in order to get "Include" and "Exclude" fields as separate ones…
Frendly
Paul
1,77245385090552...
Perhaps we could have 2 text fields, one for exclude, one for include???
Yes, but…
:) That could be much clearer and efficient.
- But why not use the exclusion syntax with the pipe "|" ?
- Like Paul points out above, this saves a field on the box, and doesn't need to change the GUI…
:mrgreen: KR
marsh
Re: Yes, but…
Post by marsh »
Clo wrote: - But why not use the exclusion syntax with the pipe "|" ?
I'm not sure the seperator idea would work well with current '*custom' box/idea.
In other words, "primary|secondary" sequence for input box depending on existing custom checkboxes- that would mean it could act both like "exclude|include" AND/OR "include|exclude" at same time?
Cheese OR dessert…
—> marsh
:) Hello B. !
• The snag is that currently, one can only either include OR exclude using that field…
- With two fields, it could be something like below :
———— Image
- It's better yet, but IMHO, a special setting-page should be the best, with i.e. one field per column using the separator.
- All cases could be supported, could they not ?
:mrgreen: FR
Olivier_G
Post by Olivier_G »
Have a look at the Include/Exclude part of this suggestion:
Self explanatory, very flexible... and the 'custom' line is not even needed.
Olivier
A patch---
—> Olivier_G
:) Hello, bonjour,
• In the meantime, I have drawn a patch to illustrate that I meant…
- I guess that the principle is similar to your approach, but with regard to the existing stuff and my own proposals …
Just quick made :
——— Image
- I need a rest now :P
:mrgreen: KR
Dreamer
Post by Dreamer »
Clo - looks too confusing, "|" is not a standard, not good for normal users IMO.
What about this:
[exe com    ] files    [x]  [ ]  [x]  [x]
[pdf eps    ] files    [ ]  [x]  [ ]  [ ]
Simple, good configurable - include/exclude even for specific action - and probably quite easy to implement (no need to change whole dialog).
Dreamer
What standard ?
—> Dreamer
:) Hi !
• The pipe | IS a standard item in configurations !
- It's not for you because you aren't a TC user :P
- And I don't see what is confusing : Just read…
- Anyway, less confusing than the current box where it's impossible to know what does what !
:mrgreen: KR
