@icon sushi - image to icon converter
All non-XnView related: softwares, formats, imaging, photography...
Lesmo16
Post by Lesmo16 »
@icon sushi is an image to icon converter that supports mask editing and creating of Windows XP 32bit icons.
- Support for Windows XP 32bit Icons
- Support for Multiple-Icon which contains some icons in a file
- Edit Alpha channel and Transparency-Mask
- Open 1x1 to 128x128 size of images
- Open 1/4/8/24/32bits color images
- Import: ICO/BMP/PNG/PSD/EXE/DLL/ICL
- Export: ICO/BMP/PNG/ICL
- Copy to / Paste from Clipboard
- language files available on HP
Current versions: 1.19 stable and 1.20 beta2
HP: http://www.towofu.net/soft/e-aicon.php
Everyone who believes in telekinesis, raise my hand!
Nice
—> Lesmo16
:) Hello Thomas !
• Nice, I've installed it some weeks ago, especially to create certain ICLs… :wink:
- It's the 1.19.0.1 version, no big problem… However, I had to complete and correct the French language file a lot…
- I've even sent that programme to Pierre (to test some ICLs issues in XnView).
• A good freeware, very useful. Just an irritating detail - at least for me - : The Win buttons have an extra state, and that turns me crasy each time I use this ! :P
Thank you to have posted that news !
:mrgreen: VG
Moderator & Librarian
New version
History of @icon sushi:
1.21 (Feb 04, 2007)
- Added: Support Vista icons. (read/write from/to *.ICO and *.ICL)
         Therefore now up to 256x256 of image sizes are supported.
         If you wish to save to vista format, choose [Options][Icon Save Format][Vista Format]
- Fixed: View size ComboBox did not work.
- Fixed: Text color did not inherit windows design settings.
- Fixed: In some cases, list images and large icon images were not displayed correctly.
- Fixed: Error occurred when saving many icons to *.ico or *.icl file.
Updated…
—> XnTriq
:) Hello !
• Thank you for the info.
- I've updated the programme, and also the French language file (not provided in the package…).
- So, if you'ld want for it, please just ask for… :wink:
:mrgreen: FR
Re: Updated…
Clo wrote:- I've updated the programme, and also the French language file (not provided in the package…).
This may be of relevance to you, then:
I downloaded the EXE installer as well as the ZIP archive. The executables in both packages are identical (FC /B), but the *.lng files are not (WinDiff):
  • “StringVersion 1.21 beta1” (aicon121setup_e.exe)
  • “StringVersion 1.21 beta2” (aicon121.zip)
