Drag/Drop Folder Movement and Manipulation
Bill Dempsey
Post by Bill Dempsey »
I'm a photographer. I have hundreds of folders of images on my large hard drives. Your program let's me find and move images around better & faster than any program I've used except for one major problem. I am not able to drag entire folders into other folders using the browser. This would be a HUGE benefit for grouping and sub-grouping images. As it is now, I have to find the folders with the correct images using your browser and then go out to Windows to move that folder to another folder. It's cumbersome.
Please add the ability to move folders around into other folders.
Dreamer
Re: Drag/Drop Folder Movement and Manipulation
Post by Dreamer »
Bill Dempsey wrote:I'm a photographer. I have hundreds of folders of images on my large hard drives. Your program let's me find and move images around better & faster than any program I've used except for one major problem. I am not able to drag entire folders into other folders using the browser. This would be a HUGE benefit for grouping and sub-grouping images. As it is now, I have to find the folders with the correct images using your browser and then go out to Windows to move that folder to another folder. It's cumbersome.
It works good here, strange, could you explain more please? What version do you have?
Dreamer
Bill Dempsey
Dragging Folders in directory tree
using Version 1.82.4 in Windows XP
When I try to drag a folder in the directory tree on the left side, it doesn't drag. I want to be able to click and drag a folder then drop that folder inside another folder in that tree diagram on the left side. Also when dragging an item, and you hit the top edge or bottom edge of the displayed portion of the list, it should normally scroll to allow you to drag a folder to another folder that isn't currently displayed.
Dreamer
Re: Dragging Folders in directory tree
Post by Dreamer »
Bill Dempsey wrote:using Version 1.82.4 in Windows XP
OK, I tried to drag a folder from the browser to other folder in browser and to folder tree. Folder from folder tree to 'somewhere' doesn't work, confirmed.
Dreamer
