Fit image to window, all
Stephan
Post by Stephan »
The function "Fit image to window, all" doesn't work probably anymore (in version 1.65 & 1.66).
In older versions this function was activated with "CTRL + I" - now it's "/" but it works only on the current picture.
Any help?
Re: Fit image to window, all
Stephan wrote:The function "Fit image to window, all" doesn't work probably anymore (in version 1.65 & 1.66).
Any help?
Yes, you must set the option in options/View/Fit
Regards. Pierre.
sycho
Post by sycho »
Yeah, solved my problem. ;)
Thanks for XnView, it rocks.
In older versions ...
The setting 'Auto image size' in the options is valid for all images opened, whereas the setting in the menu 'View->Auto Image size' applies for the current image, only. Hope this makes the difference clearer...
