Pasting Office pictures
szlori
Post by szlori »
I have the following problem in the Browser mode:
  • * Open an Excel document that has embedded picture object (this was created by using Insert picture from file)
    * Select the object and copy to clipboard
    * Try to paste it in XNView (Ctrl+Shift+V) -> doesn't work, Import clipboard menu item is actually disabled
I have no problem to paste it in Viewer mode though...
There both Paste and Import Clipboard work.
And if I close the Browser window as well, File->Import clipboard also works.
Is this a bug?
Thanks!
Re: Pasting Office pictures
szlori wrote:I have the following problem in the Browser mode:
Is this a bug?
Thanks!
Strange, i have not this problem with 'import cliboard'...???
szlori
Post by szlori »
Is this a bug?
Thanks!
It happens for me consistently, but only in case of copy-pasting from Excel.
I tried with MS Word, but it worked.
I'm not sure why it wouldn't work from Excel, it's really strange. :(
  • Open Excel (I'm using Office 2003) and Import from file a picture into an empty sheet.
  • Click the picture and select Copy
  • Switch to XnView (which is in Browse mode) and verify that Import clipboard is disabled
