contactsheet from eps and ai
aussenboarder
Post by aussenboarder »
hello.
as i am quite new to xnview i need to ask you something.
my idea is to build up contactsheets from multible eps files which cannot be
previewed by other filebrowsers. that works fine so far.
1) question: is there a way to automatically save all these conactsheets that have been created?
2) is there an option to set up a border around every thumbnail on that contactsheet?
3) another suggestion: is there a command line scripting which could help me out?
4) does anybody know how to build up a contact sheet out of adobe illustrator files?
thx for comment. cheers, aussenboarder
Moderator & Librarian
Re: contactsheet from eps and ai
aussenboarder wrote:1) question: is there a way to automatically save all these conactsheets that have been created?
aussenboarder wrote:2) is there an option to set up a border around every thumbnail on that contactsheet?
aussenboarder wrote:3) another suggestion: is there a command line scripting which could help me out?
aussenboarder wrote:4) does anybody know how to build up a contact sheet out of adobe illustrator files?
aussenboarder
hi again.
creating a contact sheet is still a problem for me. to illustrate what i am
talking about i made 2 screenshots.
>> result of "xnview website generator"
>> result of "xnview contact sheet generator"
i like the result the website generator builds up because every thumbnail is
separated by a surrounding border. this seem to be not possible with xnview's
website generator.
because of this i took several looks on nconvert but i can not find out how
to build up a contact sheet using the command line options. - i hope this is
what you suggested?!
could you please supply an example command line?
thanks a lot. - aussenboarder
aussenboarder
hello.
can i create such a webgallery or website from multiple folders, in which
images are stored? i could not find a way, maybe there are command line
arguments to do that.
regards, aussenboarder
