High quality zoom in Slide Show
Mugendai
Post by Mugendai »
It seems that in slide show mode, the high quality zoom isn't used.
By this I mean the slideshow, slideshow mode. Not the kuhl new quick slideshow mode.
Also, a shortcut key for starting a slideshow with that kuhl new quick format would be quite nice as well.
Re: High quality zoom in Slide Show.
Mugendai wrote:It seems that in slide show mode, the high quality zoom isn't used.
Yes, right. I must add "high zoom quality" in slideshow & browser's preview
Regards. Pierre.
Post by Guest »
Hi, this feature is going to be done anytime soon?
Anonymous wrote:Hi, this feature is going to be done anytime soon?
This feature has been requested several times and is high on Pierre's ToDo list. Think this will make it into the next release.
Similar requests:
- Slide Show Problems with 1.74
- Slideshow does not use High Quality Zoom
- Haute qualite en diaporama...
Dreamer
Post by Dreamer »
xnview wrote:Yes, right. I must add "high zoom quality" in slideshow & browser's preview
Posted: Wed Nov 05, 2003
helmut wrote:This feature has been requested several times and is high on Pierre's ToDo list. Think this will make it into the next release.
Posted: Thu Dec 23, 2004
High quality is still missing in both modes in 2008!!? :(
Moved to Suggestions.
Dreamer
Dreamer wrote:High quality is still missing in both modes in 2008!!? :(
Missing??? But you have high quality in slideshow
Dreamer
Post by Dreamer »
But I mean Zoom in - high quality for small pictutes if option "stretch small pictures" is enabled.
Dreamer
Dreamer wrote:But I mean Zoom in - high quality for small pictutes if option "stretch small pictures" is enabled.
I've tried, and i have smooth zooming for stretching picture too
Dreamer
Post by Dreamer »
Hmm.. here are the screenshots from 1.94.2:
Preview:
Slide Show:
Viewer:
Dreamer
Xip
Post by Xip »
For me there is a very noticeable difference in quality, especially for small images that are scaled up, between the fullscreen slideshow and the fixed size slideshow. It seems that the high quality option does not work for the fixed size slideshow but does work for the fullscreen slideshow. Possibly a bug?
Dreamer
Post by Dreamer »
Xip wrote:It seems that the high quality option does not work for the fixed size slideshow but does work for the fullscreen slideshow. Possibly a bug?
That's it!! Thanks Xip!
OK, so to reproduce use small pictures and fullscreen mode, then the same pictures and window mode with big resolution - the same as your screen.
Dreamer
