viewing 12 bit image file
ZELLIS
Post by ZELLIS »
we use 12 bit image files and would love to use XnView to display the imagery but your current version only supports 8 bit files. it sure would be nice to pull up a 2016 x 2016 x12 file format. is this something that can be done?
thanks.
great viewer
Olivier_G
Post by Olivier_G »
I use XnView to display 16 bits TIFF images (Black&White 16bits and Color 3x16bits) without problem.
Could your provide more info: image format and maybe a sample?
Olivier
Zellis
Post by Zellis »
the format is RAW black&white 12 bits the image size is 2016 x 2016. the sample is a 8 meg file how should i send this to you?
Drahken
Post by Drahken »
you could use http://rapidshare.de/
Olivier_G
Post by Olivier_G »
Zellis wrote:the format is RAW black&white 12 bits
It's probably a RAW format not yet handled by XnView (there are actually many different RAW formats, specific to each system) => what system/camera does it come from?
I won't be able to help you much, but you may try to update this thread next week, as Pierre (author of XnView) is currently on holiday. He usually needs a sample to implement a new format...
(and more people may try to help meanwhile if you make the file available as suggested by Drahken)
Olivier
ZELLIS
Post by ZELLIS »
thanks, ill update next week. as for sharring the sample file, our firewall block the site. ill try to send it once i get home from work.
ZELLIS
Post by ZELLIS »
this is a repost suggested by Oliver_G so that Pierre (author of XnView) could possibily help! Oliver has a sample image and i can also supple one if needed. thanks.
thanks.
great viewer
thanks.
great viewer
ZELLIS
Post by ZELLIS »
here is a link to Download the sample:
Http://www.hyperupload.com/download/021 ... e.raw.html
Which extension ?
—> ZELLIS
:) Hello !
• From your link, I got a file <good> without any extension 8,128,512 bytes… :?
- Please, let me know what that file is exactly, I can't attempt to open it currently, I'll go certainly to a failure… TIA
Note : in XnView, I see only a tiny image 12*14 "24 BPP" :P
:mrgreen: KR
Olivier_G
Post by Olivier_G »
I zipped the file to 52KB here. It's a specific "raw" 12 bits grey image that should be displayed as follow:
(provided by Zellis, as I couldn't view correctly this raw file)
Olivier
:? I had the same saved from the forum as PNG 8 BPP which is viewable…
- The RAW file from your ZIP is fancy displayed as a 256*256 24 BPP here…
…while the size is reported as 7.75 Mib (that is correct) :
———— Image
• Zooming in, you can see "virtual" colours, while the pic might content only "Greys"
:P :?: :!:
:mrgreen: KR
Olivier_G wrote:I zipped the file to 52KB here. It's a specific "raw" 12 bits grey image that should be displayed as follow:
Ok, currently RAW format with 8bits are only supported...
ZELLIS
Post by ZELLIS »
would it be difficult to add support for 12bit raw format? is this something you would be willing to implement?
thanks again for a great viewer. :wink:
ZELLIS wrote:would it be difficult to add support for 12bit raw format? is this something you would be willing to implement?
I'll try to add RAW 12/16 bits
