Alpha channel in PNGs
SharkD
Post by SharkD »
Two problems:
1) XnView reports all my 32-bit PNGs as 24-bit, TrueColor--despite displaying the files properly
2) alpha channel is lost when cropping images
SharkD
Post by SharkD »
I'm using the March 3, 2006 build.
SharkD
Post by SharkD »
Sorry for the three posts.
Anyway, I just checked, and it's only reporting the bit-depth improperly in the status bar of the program. If I view the file's properties, then the bit-depth is reported correctly.
Re: Alpha channel in PNGs
SharkD wrote:1) XnView reports all my 32-bit PNGs as 24-bit, TrueColor--despite displaying the files properly
It's a known issue. Please take a look at this & that.
SharkD wrote:Sorry for the three posts.
It's because you have option/png/Read/compose...
