g'day all,
Just noticed that 10bit DPX files created by XnView 1.70.2 and 1.70.3, are causing a lot of crashes in other software, such as shake and cinePaint. Loads back into XnView ok.
Wondering if the format was to spec?
Also, does XnView support proper 10bit files yet, or are they still converted to 8bit on loading, and from 8 bit to 10bit on saving?
Thanks
Dave
DPX Output - corrupt header?
Re: DPX Output - corrupt header?
Do you have a 10bits DPX created by shake or cinepaint?Anonymous wrote:Just noticed that 10bit DPX files created by XNView 1.70.2 and 1.70.3, are causing a lot of crashes in other software, such as shake and cinePaint. Loads back into XNView ok.
10/12/16bits DPX files are converted on loading.Also, does XNView support proper 10bit files yet, or are they still converted to 8bit on loading, and from 8 bit to 10bit on saving?
And you can save 10bits from 8bits on saving.
I have a file that loads in various other tools, so where do you want me to send it??
If I get this file, load it in XNView, save it back out (as 10bit), and then try to load it in Photoshop CS, the original will load, but not the XNView version.
Also on the save out, is it doing a 8bit to 10bit conversion? I gather from your previous message that the 10bit data is lost in the downconvert on load, so saving back out at 10bit wont be seemless.
Thanks
Dave
Thanks
Dave
You can use contact-nospam@xnview-nospam.comAnonymous wrote:I have a file that loads in various other tools, so where do you want me to send it??
(Remove -nospam)
To save a 8bits picture into 10bits, you can set a 8=>10 log lutIf I get this file, load it in XNView, save it back out (as 10bit), and then try to load it in Photoshop CS, the original will load, but not the XNView version.
