Favourites: Context menu
The entries in the list of changes of 1.90 alpha are sorted, I start with the top entry which says "* New panel in browser (tab for favorites, and tabs for info/Metadata)".
The new Favourites panel (View > Explorer pane > Favourites) is good. Though it makes me a bit wonder why we have the small symbol "Favourites" and its functionality in the small toolbar plus the Explorer pane. One or the other seems redundant to me. In alpha1 the "Edit Favourites.." dialog does not allow for creating subfolders or adding entries, so the new explorer pane offers more functionality. The favourite handling should be unified or the old dialog should be removed, I think. Having two spots for the same thing does not make sense to me.
When right clicking on an entry, the context menu appears. Currently, the entries are:
Delete
Rename
New subfolder
Edit entry...
Add entry...
Sort entries
I think that the context menu of the Favourites pane should be similar or close to the handling in the folder pane. The difference to the folder pane is that we can create two types of items: Folders and Favorites.
The first thing that I would like to swap is the symbol of the favourites and the symbol of the folder. In alpha1 the folder is a star, whereas the favourites have the folder symbol, it should be the other way round.
What about the following order and naming of the menu items:
New favourite...
Edit favourite...
New folder...
Rename
Delete
Sort
V 1.90 A1
Dreamer
Re: Favourites: Context menu
Post by Dreamer »
helmut wrote:The new Favourites panel (View > Explorer pane > Favourites) is good. Though it makes me a bit wonder why we have the small symbol "Favourites" and its functionality in the small toolbar plus the Explorer pane. One or the other seems redundant to me.
I disagree, folder tree can be disabled, also "use tab" can be disabled, then it's not redundant. ;)
helmut wrote:The first thing that I would like to swap is the symbol of the favourites and the symbol of the folder. In alpha1 the folder is a star, whereas the favourites have the folder symbol, it should be the other way round.
I agree.
Dreamer
helmut wrote: The first thing that I would like to swap is the symbol of the favourites and the symbol of the folder. In alpha1 the folder is a star, whereas the favourites have the folder symbol, it should be the other way round.
Which symbol??
Which symbol??
The symbol for favourites and the symbol for folder. Folders look like favourites and favourites look like folders:
helmut wrote:
Which symbol??
The symbol used for folder comes from explorer, i use only the star for sub folder. Which symbol will be better than star for sub folder???
Olivier_G
Post by Olivier_G »
xnview wrote:The symbol used for folder comes from explorer, i use only the star for sub folder. Which symbol will be better than star for sub folder???
You can't invert them? (use 'star' for favorites / 'folders' for the structure)
Olivier
No, for folder i extract from explorer the icon. So the only icon that i can change is the star for subfolder...
The Star sucks !
:) Hello Pierre !
• Please, could we have the "Favourite" icon from the current skin instead the "Star" ?
- Maybe as an INI option ? TIA !
:mrgreen: KR
Re: The Star sucks !
Clo wrote: • Please, could we have the "Favourite" icon from the current skin instead the "Star" ?
I've checked my code, and i can't change that. I use standard explorer icon list...
Pierre, as you can see above, the symbols are simply the other way round, favourites should be a star and folder should be "folders". The way it is now is very misleading and confusing.
Is there really no way to change the icons used in the favourites tree?
Note:
I just had a look at MS Internet Explorer. There, folder are folders and bookmarks are shown as HTML documents with the blue "e" of the internet explorer.
From a DLL¦ICL
—> Helmut
• Thank you to have checked this.
- IMHO, a trick¦workaround could be found…
- For instance, we had Win folders icons in the list of Total Commander (V 6.5x…),
and some system folders were always shown as 16*16, others rescaled and damaged, this was ugly [Left] :
——— Image —— Now from TC resources : —— Image
- It could be got from some icon¦bitmap DLL as well…
This exists too in TC, where we can choose an alternative external resource for this kind of images…
:mrgreen: G
marsh
Which explorer?
Post by marsh »
"Star icon" does not appear on win2k (ie5). If some are old favourites and others are new folders, how does one tell them apart?
"C:\in\test"*"C:\in\test"
<New Folder8>
</New Folder8>
I always use the path as favourite name. So you can see how this can be confusing.
Re: Which explorer?
Strange, on my W2K, i have star. I must choose the icon for a existing file for folder in favorites, so which?
Currently i use the favorites folder from Document and settings!
marsh
Re: Which explorer?
Post by marsh »
xnview wrote:
marsh wrote:
xnview wrote: I've checked my code, and i can't change that. I use standard explorer icon list...
I think I have found a windows buggy patch which causes star to wrongly appear on folder instead of favourtites, stay tuned! I have been reinstalling OS suspecting something wrong. Fully patched doesn't look like base installation.
marsh
Post by marsh »
The "Star" behaviour in alpha3 changed when I uninstalled and reinstalled ms06-051_windows2000-kb917422-x86-enu.exe! (this seemed to fix star placement problem).
Base install (unpatched)= stars used on some favourties (but not all).
Fully patched= Stars are on folders (as Helmut reported, but I could never see it before- I don't know why).
