Compare... and new "Use Tab" :-)
ch3n3
Post by ch3n3 »
The new compare (picture) mode with "Use Tab" is very very usefull for me (thank you Pierre :D )
Is it possible to have a Key :?: ([Tab] ? or [²] ... or other ;-) to switch one Tabs to the other (without using the mouse) ?
Regards,
XnView 1.90 <x>
Olivier_G
Post by Olivier_G »
I don't know if this is exactly what you asked for, but by using [Tab] key (3 times), you can get keyboard focus on Tabs and you will be able to switch easily between them with the Left & Right arrow keys (without losing focus while using buttons or panning image).
It might be possible to improve it, though... :?
Olivier
Re: Compare... and new "Use Tab" :-)
ch3n3 wrote:Hi,
Regards,
You have Ctrl+Left/Right when focus is on tab
